I can’t see environnement reflection in BPR render. The standart reflection (ie : texture map only) are OK , but I don’t see subtool reflected on another subtool. Of course, i have not forget to put value on the Env Slider of the material and when I do a standart Best Render, it shows reflected subtools.
Is it a bug or a non implemented feature? the ZB4 doc says nothing about that.
Not all features work with all renderers. But what you can do is do a Best Render followed by a BPR. The BPR will be overlaid on the Best Render, so that you get the effects from both.
Yes, that’s what I’m going to do. Thanks for help.
