Borg Collective Attack Fleet
For this picture I used the perspective feature. For those that don’t already know, if you select “persp” under the draw menu and set the distortion slider to zero also under the draw menu, you can get perspective with the vanishing point in the center (Note: this has to be set for each new tool you select). I then placed the basic shapes using a purple glow material and used a marker for each one. Then on a separate layer, I used the same shapes, but inflated using an alpha map to mask it. I then inverted the points on the tools that were masked and selected “hide points”.
The alpha maps were created with pov-ray using a script which made use of the rand function. If I had ZBrush 1.23, I probably could have made the alpha maps in ZBrush in short order. I did it that way, since the textures would have been far too tedious otherwise.
Anyway, here’s the picture. I was also a little “creative” with the color scheme since anyone who’s familiar with Star Trek, knows that Borg ships glow green and not purple. :wink:
This feels like it’s about a thousand miles deep. One of the grandest images I’ve seen here. Thanks for the process description. The glow material is my personal favorite :+1:
Great image, thanks for the info!!! :+1:
Cool Shinzaho.
I’ve just discovered the perspective button in the draw palette myself a couple of days ago! (funny how you new things keep poping up!)
Thanks for the Hide-Points info. That was new to me as well!! I’ve had a wee play with it and it’s opened up a whole new tool for me to use to create perspective rooms!! Excellent!!
Hey, I’d be interested in some of your Pov-ray script info. Whats a Rand function??
Shinzaho, I hope it’s not too rude to ask, but could you make your pictures a little smaller? - width ways?? It’s just that I’m scrolling left and right to read your posts on my laptop (I’m being picky, I know!)
Your’ve got a lot of un-tapped talent there bud, and I’m enjoying reading your posts! Keep in touch!
Upham :slight_smile:
what a threatening armada popping out of (or is it into?) space! :+1: :+1: :+1:
thank you for sharing production insights, too, Shinzaho!
  • juandel
We are the Borg. Resistance as you know it is over. We will add your biological and artistic distinctiveness to our own.
hehe. Nice work Shinzaho!
What Stacey said :slight_smile: Great image and description of the process, most appreciated.
