Good job blueferret, some work flow?
a hug
Blue those are from ZBC screwing up, they are either those smile things everyone types and ZBC tries to translate into icons, or another language which ZBC prevents outright.
I noticed this a while ago trying to do things like say stuff in Greek, ZBC actively prevented it.
Basically “*** 8203” is something other than a number.
Yhago is from Spain and I think they have a couple of characters we do not.
These things you are making are wonderful, and you are inspiring all sorts of people with them and that is terrific!
Cheers!!
Thank you for your clarification Maleaying on my post.
Blue Ferrets, I meant that there are certain ways that no longer can be made manually.
My line of work I put in your post because it is similar in ways to yours and perhaps could share ideas, not to work like a bastard cousin. I regret not having made me understand you.
I find it very interesting your work
So which post are you talking about that you wanted a explanation for…and I would be more than willing to work with you on any projects… greetings and salutations… Deke
This is called a Metatron…Hope it pleases the eye…
Circuit board workflow…
plane subd several times
Polish h brush over some of it
cavity masking
separate into group loops
pick one and deform and the paint. size and inflate
mask the inverse
make group and paint that one , invert mask paint the other…
Lighting and done…
thin wires are edge loop deformed with size…
Post 405…Needs little people doing something and seen seen through those windows by the viewer///will give it scale…2001 A Space Odessey :D…Nice work Deke
small_orange_diamond:)
Glenn
Hi, We started to draw shapes impossible to do manually in clay, CAD and 3D printers help us make it happen, but we started to give them boundaries reach or revise such forms brightness or create molds for playback in series
Mersh Cutouts made from a texture…
That looks really good blue.
Thanks just a different process that doesn’t use Shadowbox and seems to work for a real nice clean mesh…
The Earth held together inside and out to keep from shattering its fragile contents, US… Deke
Ah if we could only be as transparent in our politics and our morals…
Turbo City …
FANTASTIC
Your integration is excellent - I like the added touch of the propeller.
Thanks, appreciate all comments… Deke
Really appreciate the comment on integrating it, was a lot harder than it looked
Sort of an ethereal take on a torus…
A Crystal Skull …
cool effects…its alway interesting experimenting with transparency and reflection…would be cool to transfer this models on 3ds max or similar software to render reflections or caustics lights for example…
