Hello guys.
I wrote about this a while ago but never got an answer.
Is there a way to export bigger Normal maps than 2048x2048.
I can’t find where to set this up. I’m currently on zBrush 3.5 on the Mac.
Thanks in advance
Pablo
i know i had this problem when making my texture maps. try going under UV map and set the size you want. then make the normal map and i think it should use the size you chose. hope that helps
Thanks man. I’ve been exporting my models at the highest level only because of this problem. And since I render with mental ray which doesn’t like highpolycount. I’ve been having a lot of problems.
Thanks again.
no problem
how did you get 3.5 for mac? I’m on 3.2 and have been waiting for 3.5 for a LONNNGGGG TIME
