Hello, here I have a problem that I do not manage to solve. I have to use the method of Scott Spencer but also the tutorial ones of Digitals-Tutors but each time I have this problem (see the image). Do you have an idea? Thank you for your assistance
Lordpissang
Are the points even welded?
I think that I have a problem with my basic mesh, because with a primitive Import Export Maya to zbrush is normal. But when it is a mesh which I built that gives me this error. So i do not manage to check with exactly if my mesh is clean
Sorry for my english :o
If that jpeg is a Maya MR render, it’s because you didn’t have your Mesh highlighted when you created your subdiv Approx, and/or your Displace Approx. I bet that’s all it is…
Let’s try this again… If that jpeg is a Maya MR render, it’s just that you didn’t HIGHLIGHT your mesh while creating a Subdiv Approx, and/or your Displace Approx. Make sure it’s Glowing Green.
