I’m trying to prepare a project for print. Across all subtools I have a total of just under 13 million points. When everything is merged down to one tool and dynameshed I can’t seem to get over 3 million points. This is not an impossible resolution but I’d love to have one tool at twice that rez before I create a shell and decimate for print.
I’ve tried Dynamesh and no matter what physical size I change the tool (to get a larger bounding box and more detail) I still end up at just under 3 million points. Even if the slider is set to 1024 and then I jump to 2048 or really any value, I still get a number under 3 million. Sometimes the number of points will even drop slightly lower.
Using the Dynamesh Master (which I really love otherwise) I can’t seem to break the 3 million point barrier, even with auto scaling on and no matter what I set the desired point count to.
- Am I missing something obvious?
- Is there a better workflow? I’m using Dynamesh (and ultimately with a shell) to Decimation Master.
Thanks All:D
