Best way to get Z n C4D to play together ?
My OS is windows vista 64 bit
zBrush 3.5
Basic C4D 9 I know it’s a little out dated.
Bodypaint 2
Want to model a base mesh in C4D send to Z model detail n texture then
send back to C4D for posing n rendering.
is there a goZ version any where that i could use ?
if there is no GoZ version i could use
Can i use displacement maps ?
or what should i do ?
i have not ever done any thing like this before
thanks for any help
GoZ currently only exists on the Mac platform. If you are using Zbrush 3.2, you can make use of it. The PC version is due in the coming months.
As far as C4D, look through the tutorial forums…one of the first threads in there is a ZB to C4d thread:
http://www.zbrushcentral.com/showthread.php?t=76232
Diligent searching will turn up more.
kool tutorail but does not anser the qwestion i seek.
I have been Diligent with the tutorails,manuel , video’s ect ect.
There is a lot to scan :slight_smile:
last time i used zBrush was 1.55b been to long I know.
I never had zBrush 2 Do not know how good it worked but I know thay used micro displacement maps at one time.
Was woundering if that is how it is still done or if there is another standered now ?
You may find This helpful.
Even if a C4d user happens along here, your inquiry is rather broad.
