Best quality of projected Texture in polypainting?
Hi
it did a character and polypainted the texture with the help of Zaplink to PhotoShop. I took some pretty high res pictures and used them for projection. Saved the file in PS and went back to Zbrush. Right after I accepted the projection Zbrush tried to project the texture BUT ends up with a very lowres version. I cranked up the subdivisionlevel to VERYVERY high. But with the same result. My document size is still 2048x2048 and I use as much space as possible.
If I use 4096x4096 my PC will calculate a lot.
How to get a high detailed projection???
Thanks in advance for any hint!
Kind regards
Hilmar
