Beginner - Few problems and questions
Hello everyone,
I’m currently working on a project, it’s kinda odd to explain. But basically import a model into a game, however the game is strict, and there fore I’ve tried quite a few programs out, someone directed me to Zbrush and so here I am.
Anyway, I have a few questions, and I took snapshots hopefully to make this as easy as possible. I assume they’re easy problems to solve to people who know their way around.
My first problem is my symmetry is messed up. I’ll hover over an object, and the “symmetrical” dot is off my model. I did do a google search which landed me to a forum post with someone of a similar problem however I can’t find the button that apparently fixes the problem. :confused: C.Pivot? It’s on the “top right shelf” or so it says on the post but I can’t seem to find it…
Another question is,
<img src=“http://www.zbrushcentral.com/upload/atn.gif”>
As you can see I have a rough sketch in the background and am working from the side view. Anything I do to this side though I want symmetrically on the other side but when I enable symmetry it does it on the wrong axis.
How would I change that?
And my least and final question is about saving. I was reading through the faq and came upon a section about 2D image, and loosing the edit section. So pretty much if I wanted to save the project above and continue right off (I tried save-as then opened it but couldn’t edit the model anymore) I have to save the tool and reupload that?
Thanks for any help in advance, I apologize if this is a long post.
Hello Snowfox17, to answer your first question – the C.Pivot button can be found in the Transform palette. I think you need the S.Pivot button first, though. (same palette) :slight_smile:
Here are some links which might help you on this subject:
http://www.zbrushcentral.com/zbc/showpost.php?p=579198&postcount=4
http://www.zbrushcentral.com/zbc/showthread.php?t=67224&highlight=pivot
http://www.zbrushcentral.com/zbc/showthread.php?t=54071&highlight=pivot
Regarding the wrong axis –
you can change the axis: Transform palette --> >X< >Y< >Z<
http://www.pixologic.com/docs/index.php/Transform_Palette#Symmetry_Controls
I hope this helps. Im not sure because I cant see your pictures.
How to post images at ZbrushCentral:):
http://www.zbrushcentral.com/zbc/showthread.php?t=68060&page=1
Regarding your last question:
http://www.zbrushcentral.com/zbc/showpost.php?p=581682&postcount=2
Hope this helps
