baking matcap into PolyPaint: anyway to get that info outof Zbrush?
So I recently noticed in the “Z-classroom” section of the Pixologic site, there are some tips and tricks on PolyPainting…when I first got this video going, I was delighted to find the narrator incorporate a z-material into his poly painting process…He simply enabled mrgb, had a color designated, and using what must have been some kindof skin material, he “filled object…” this immediately gave the model a more naturalistic look, and he continued to paint away…so, when all was done, he converted the col>texture, and it doesn’t seem that he retained anything but the dappled brush strokes he made after filling his object (which does not yeild a fair reproduction of what he had in the zbrush viewport)…the narrator didn’t mention that the captured texture was nothing more than the few strokes on a white background…when I go through this process, this happens to me as well…so,…I’m writing this post with the slim chance that not only had i missed something while watching the vid, but that my personal results are off as well, and that one can through some technique or trick capture that material info baked with the painting…otherwise I think the usefulness of that tutorial is a bit limited,…why even capture the thing to texture if u can’t reproduce the look outside of Zbrush? Don’t get me wrong, its great for preViz purposes, and perhaps bouncing in and out of Photoshop, but really there should be a way to bake it all in so it can be used for production…anyways, if anyone has info on this, or has polypainting workflows they’d like to share that would be great,
thanks,
-j
j,
Have a look at these tutorials… might do what you want.
Mat baking
Sven
wow…okay…thanks a ton for these totorials! This seems to be the only way to approach this issue til its more integrated in further releases of Zbrush…so I’m guessing that u’re workflow (following u’re second video’s method) would require capturing in sections…so u might zapplink capture for the head,…torso, arm, ect…is this correct? Otherwise I would suppose u wouldn’t get the accuracy needed…also…I’m getting massive artifacts so far…is this just a polycount issue, or is there something else I should keep in mind?
thanks again for posting vids on this,
-Josh
Those and many other tutorials on the forum were authored by Cannedmushrooms… you should ask him your questions. I do know for sure that the quality of most polypainting naturally improves with increased resolution.
Sven
perhaps its my lack of sleep,…but I had mistaken you (svengali) for the author of these vids…I’ll make sure to contact “CannedMushrooms” for furthers questions…
my apologies,
j
