B key is not working anymore
Hi there
I’m trying to figure out why the b key that brings up the brush dialog is not working anymore.
I restored to the original ui configuration but it’s still not working.
I think also that lightbox has a different keystroke assigned to it?? Now it’s assigned to coma (,)
Any ideas how to bring back the original shortcuts?
The comma key is the default for Lightbox. If you modified your hotkeys then perhaps you have re-assigned ‘B’ to something else? You can restore the original hotkeys by copying the attached file to your ZStartup/Hotkeys folder, replacing the file there.
Thanks man!
Yep I made my custom keys but I have no idea how the shortcut got deleted.
Since I wanted to keep my own shortcuts but still have the default ones I copied and pasted the ones I was missing (the standard brush key when in popup mode) from your file to mine and re-saved.
Many many thanks!
