Auto-switch ALT-brush???
Hi, I have a question:
I’m mostly using the Claybrush for ZAdd, but when I press ALT, I’d like to switch to the Formbrush for ZSub.
Is there a way to do this? I read something about using a Macro, but I don’t follow it!
Thanks
Alt has a very specific function: activating alternate behavior (usually by reversing effects). For this reason, it cannot be remapped to something else.
However, you can change the brush that’s called by Shift. By default it’s one of the Smooth brushes, but if you Shift+click on a different brush that one will then be activated every time you hold down the Shift key.
