These are beyond great bro. Thanks for sharing them with us.
stevef, usurpator, sculptor.zb, boblenain, Nyx702, UnitO, KC-Production, mschri2008 - thanks alot guys, glad to hear you like
my work
This gives me strength to keep up the work for the next set of free brushes
Thank you! Also, your 2 renders are really well done. They make the new brushes look spectacular!
Thanks alot ArtBot
WOW - my brushes doodles on front page ?!? THANK YOU PIXOLOGIC!!!
thanks for the brushes
really NOOB question tho…
im loading the brushes thru the brush palette and nothing is working. then i mported the alphas and they dont seem to work either. i changed them to JPGs and they worked with dragdot but the brushes, im still out of luck. is there a special way of loading these brushes? thanks
garriola83, I saved the brushes into ZB4R3. What ZBrush version do you have?
well that would do it, i only have ZBrush4R2, i will upgrade and check it out, thanks!
Wow Aumakua! I think I love you
These have come in the best moment, I’m just working in a semi-mech model and I think I’ll do use some of your brushes. So thanks!
you rock!
Glad to be useful, guys
Just found the Brushes, Thank you for your fine work.
Camillo
Thank you sircamillo
Thanks a lot for sharing these brushes.
Have fun with them
Hey, thanks Noisy Knuckles, for sharing the alphas and the brushes, and showing off your workflow. It’s also terrific seeing that lineup of prints from different companies using different technologies.
Have you been recasting your pieces in resin before painting them? I’m only asking because I’ve found the raw output to be a little fragile, and not really engineered or intended for long term display.
Wetterschneider, thanks! the 3d prints are indeed very fragile. The thing is, my intention was to experiment with different 3d print technologies and not produce pieces for massive production. That’s why I printed single meshes, at least in most of the cases, instead of multi parts assemblies that are more appropriate for casting and such.
Also, I did not paint the colored prints by hand, it was the 3d printer model that printed the texture on the actual print, (well, except from the toon robot, which was painted by an artist at Offload Studios).
Thanks
You’re welcome.
Thank’s for sharing!
/peter
Dude, you are my hero! I love the mechanical stuff!
