Hey all, I just got a new Asus slate tablet up and running. zbrush works very well on it. sculpting from my couch is a blast. the problem is that i’m not getting pressure sensitivity in zbrush. photoshop, sketchbook pro, etc all work fine. anyone hit this issue before and solved it?
Have you made sure that the most current drivers are installed for your pen?
I have.
I actually dug around a bit and discovered a older version of the driver that enables pressure sensitivity for the pen with all apps and ZBrush. the current version as of today WILL NOT WORK.
http://www.asus.com/Eee/Eee_Pad/Eee_Slate_EP121/#download
select win7 64bit, and look for this driver under the touchpad folder.
Wacon ISD_DualTouch_V7.0.2-21
install this driver and ONLY this driver from this page. restart. zbrush should have pressure sensitivity working.
