Assigning memory for Zbrush
Hey guys
Can you assign memory for Zbrush to set the max poly count higher?
If so how,any tuts or info?
Hey guys
Yes, you can.
Preference Palette->Mem.
But be careful and don`t set the max poly count too high.
Although this was written in ZBrush 2 times I think it still holds true:
http://www.zbrushcentral.com/showthread.php?t=20976&highlight=memory
And this thread might also be useful:
http://www.zbrushcentral.com/showthread.php?t=32177&page=1&highlight=memory
If you need more infos it would be good if you post your system specs.
I have 8 gig /64 bit system Windows Vista.
Also keep in mind that ZBrush 4 is still a 32 bit application and can only use a maximum of 4 gigs anyway, even on a 64 bit OS.
