@n1agara – You’re very welcome and thanks for the response! I usually don’t critique much but that was more of a side-comment and a thing I noticed right away when I saw your work!
Erhmm… both? I would say its probably more the flow though then the actual separational depth. As I was just using the separation as the keypoint of where you should focus your eyes on so you can see what I was talking about, so I guess the main thing is the flow more than the depth of the separation. Though the middle line itself–if you’re not talking about depth–does come into play so I would say the middle line itself should flow too.
And yeah I can do it really quick. Let me download it and I’ll show you. I’ll give you two examples (the one on the render and what it would look like on a drawing so you’ll be able to tell much easier what I’m talking about. And I mean traditional life drawing which sculptures are usually based on anyways haha.
LOL – aww I feel bad for the girl haha. And I was just commenting on the butt since a poster above me had mentioned that your butt seemd somewhat flat. But from my standpoint it seemed quite beefy compared to the rest of the body so I figured you’d already tampered it without going overboard ;). Haha turns out I was right too lol… Yay. Yep that word exists haha, but I know what you mean. Either way going for a more traditional life drawing look you usually try not to oversexualize things anyways haha – that is the goal anyways.
You did very well indeed – anymore and it would of seemed odd lol. Since then you would have to beef up the thighs and and semi-up the calfs too along with the hip location etc. XD
Yeah it’s been since like the start of zBrush (2009 if I remember correctly?) that I’ve touched–though I only used it for a bit hours then–but the UI has changed to be more complex and drastically LOL!! I was like WTFFFFF zBrush, since when did you become so unintuitive?! Talk about a shock @ the year 2015!
Thanks I’ll definitely PM you for sure! Thanks again!
PS: I’ll post in a second after I go over the render to give you the example.
EDIT: Also I forgot to add I didn’t know you had models – I thought you just did this from your head!
They modelled naked?! The girl seems really pretty… :O.
