Im new to zbrush and was wondering are you guys starting from scratch or are u altering the models in the program?
I do mine all in ZBrush, I have imported from other programs though. I’m pretty sure that’s the case with most, however I do read MAYA and Max quite a bit.
It all depends on what I am doing. If I am doodling, it’s all Z. If I am working in a production environment, then it is Z and other software. Basically, what will work best with others in the pipeline. The rigger, the animator, the texture artist, etc, all have to work together and once a pipeline is established there isn’t a reason to break it unless it will speed up the entire process.
But noodles and personal work, most Z.
