Are Stencils broken in 4r4? [Answered]
I can’t activate mine. It simply blinks when I try switching them on through the menu or the short cut (alt-H).
Thanks
You need to assign an alpha to the stencil before it is activated:
  1. Select an alpha in the Alpha palette.
  2. Press Alpha>Transfer>Make St.
You will then be able to use the options in the Stencil palette to adjust the stencil how you want.
ah! thank you! :+1:
