Appending tools from Max
Hey all,
This is my first post and I guess I’m what you’d call a noob. So I’m trying to
import 2 .objs from 3D StudioMax so I can append one to the other as a sub tool.
When I do so I get 1 of 3 outcomes, repeatedly.
The first is that z brush will just crash.
The second is that I can append the second tool, but it comes in all blown up and polys go every where.
The third is that it appends, but nothing shows up.
I’m wondering if this has happend to anyone else or if anyone has anysuggestions as to how I can fix this.
Thanks.
Could you please describe what steps you’re following?
Please follow this forum’s guidelines when posting any troubleshooting inquiry. With each troubleshooting post, please include your full system specs and any other pertinent information which will allow us to determine if this is one of the following: a) user error? b) Misunderstanding of a specific feature, such as its usage and limitations? c) An item which has already been resolved. d) An item which needs to be resolved.
IMPORTANT: Before posting a troubleshooting item, make sure that:
  1. You are using the latest ZBrush version.
  2. You have a ‘clean’ ZBrush install. i.e. remove any items which you have added (such as older ZScripts and other startup items) which may result in unexpected - and difficult to resolve - problems.
  3. You did not increase the PreferencesMax polygon count or Compact Mem to a level which can not be supported by your system specs.
Any threads that do not follow these guidelines will be closed. Thank you for your cooperation.
