How do you append a subtool?
When I tried to record a macro this is the command lines it comes up with:
[IPress,Tool:SubTool:Append]
[IPress,PopUp:Xdiff]
When I try that I get this error:
Interface Item could not be found
Error: PopUp:Xdiff
IN: [IPress,PopUp:Xdiff
However when I run this one it works:
[IPress,PopUp:Gear3D]
Gear3D is one of the default available tools. However when I run it this way it renames the Gear3D to Gear3D1 and then [IPress,PopUp:Gear3D] no longer works but [IPress,PopUp:Gear3D1] does, until it renames it to Gear3D2.
I tried this:
[SubToolSelect, 1]
[FileNameSetNext,"Xdiff.OBJ"]
[IPress,Tool:Import]
Which works but only once as the Gear3D is then renamed to Gear3D1. Shouldn’t there be a simple way of appending a subtool? This is getting ridiculous for something so simple.
When I try this:
[IPress,Tool:SubTool:Duplicate]
[IPress,Tool:SubTool:MoveDown]
It should work but I run into problems with the scale between the models.
Another note is when I run these:
[Note,[IExists,PopUp:Xdiff],,0]
Returns 0
[Note,[IExists,PopUp:Gear3D],,0]
Returns 0
Returns 0
Returns 1
I just need a simple append or an import that doesn’t screw up my scale.
You could just start a project with the Cube3d in it, in edit mode. Open that and go to town with your modeling. More on scripting can be found
