As the title says, is there any way to turn off the stripy transparent look of Draw Polyframe when in Live Boolean mode? I find it visually distracting. Any help as to whether this is possible would be appreciated! Thanks!
Hi @Regal_Raster ,
You are seeing this because you have invisible/subtractive elements in your Live Boolean chain.
You can:
Disable Live Boolean Mode
Enable Solo mode so that you are only viewing one active subtool at a time.
Disable subtractive or intersect mode for any visible subtools in the LB chain.
Otherwise this effect is deliberate compromise when there are any subtractive meshes interacting so that the user can see areas of mesh that would otherwise be invisible in LB mode if Polyframe were not active, while the semi transparent aspect still allows them to see which portions of the mesh would be invisible if Polyframe were not active. There is no way to alter this that I am aware of.
Ahh that is what I figured but I thought I’d ask anyway just in case. Thank you for the response!
