Any way to lock in my Spotlight ref image?
I use Texture/ Import to bring in a ref image to my canvas but it’s not there when I reopen my file the next day. Is there any way for it to be saved along with the project?
Thank you.
Hi @cosmasad
No, there isn’t. Spotlights are saved and loaded separately.
Not sure how you’re using spotlight but you may want to check out pure ref. Its basically a very simple UI where you can put pictures in a collage sort of way. You can make it to where it always overlays your program. So you can sculpt and have some images in the top left corner of the screen.
https://www.pureref.com/
Hi @cosmasad,
Spotlight images aren’t saved in the project itself but you sure can save your current spotlight image/images including any modifications you’ve made to them including positioning, rotation, scaling, painting etc.
There’s a Save Spotlight button right in the Texture menu.
Once you open your project you can use the Load Spotlight button to open your saved Spotlight image.
Hope this helps
cheers
Thank you. This is great.
