I’m sculpting on a flat plane and keep inadvertently shifting the camera because I make broad strokes, is there anyway to disable this, or lock the view somehow?
thanks
thanks
Being more careful helps as does the Axis plug to ‘snap’ to a view.
That’s not really a solution; I’m a bit surprised this isn’t a feature.
I don’t catch your meaning, I only want to prevent the viewport from moving.
There is no magic button or setting really. Quicksketch is about as close as I think you might get…http://docs.pixologic.com/?s=Quicksketch
The dark color is just so you can see your work. If you want to rotate your work freely again just clear the canvas by pressing Ctrl+N.
Interesting fix, I haven’t tried it yet but sounds like it would work. thanks
