Any solutions similar to loft command in 3dsmax
Dear zbrush professionals, is it possible to transform a specific shape to another in a particular distance. (similar to LOFT in 3dsmax). I mean lets think of a circle on the left side and a rectangular on the right side, there is a distance between them. Is there a command to transform this circle into the rectangular ? And what may the options be ? Can we define in how many steps, etc…
Thank you in advance
No, not really. There’s the Curve Surface brush but that doesn’t have the control you want. And there’s Curve Bridge but again the result is automatic.
http://docs.pixologic.com/user-guide/3d-modeling/sculpting/sculpting-brushes/curve-bridge/
There is also the Bridge command for ZModeler. This has more control over the outcome but it’s not possible to specify the result using numerical input.
marcus_civis,
thank you for your response. so i guess the best way to gain such a model as a base mesh, is to create the basics in another host program (3dsmax for me) and import as a tool to zbrush; may be… I’ll also have a look at your suggestions “curve bridge” & “bridge (zmodeler)” --> If i’m not wrong i remember the bridge command is the connection of polygon groups within the same subtool, i remember using it in the rim training…
