Answered: User setting to home?
Hey folks,
Does anybody know what files or folders I have to take home to recreate my work settings?
If you’re on ZBrush 4R5 it is:
:small_orange_diamond: ZBrush 4R5\ZStartup
:small_orange_diamond: The ZBrushData folder. On Windows it’s in C:\Users\Public\Documents\ On Mac it’s in the main drive’s Users/Shared folder.
Of course if you have any saved content such as documents, projects, etc. you would need to copy them over as well. But the two folders listed above will synchronize all of your settings as well as any startup plugins, materials and so forth.
Thanks Aurick,
Actually Iád like to take home my custom palette, hotkeys, etc to use the very same setting at home aand at work as well…So ZStartup folder will make it for me?
I took home both folders you mentioned (excluding the quicksaves) but my custom palette was empty. Is there any tool that can help easily transfer working environment from one computer to another?
Cheers
Szabolcs
You may need an object in your scene before your pallette will display correctly. Context sensitive and all that.
Thanka for the hint…when I’m not dead tired, I’ll check it!
