I am working on learning to use Spotlight and every time I press the Z key to hide the dial ZBrush crashes.
XP Pro, 4gb RAM, ATI Fire GL V7350
Any thoughts?
Thanks,
willt
Any thoughts?
Thanks,
willt
I stumbled on a workaround for this issue.
Shift+Z to turn off Spotlight then Z to re open it and the Dial stays hidden with Spotlight active. As long as you don’t press the Z key while Spotlight is active everything else works fine.
