Answered: re-topology with zsphere breaks when Zbrush do autosave
Hi everyone, the problem appears when Zbrush refresh the auto save. So I’ve worked on a model when it made auto save and my topology cage was converted to mesh. How can I turn off this option when I work on topology? And I have one more problem. Some of my vetices freeze, and i can’t move them with move tool. I’ve read something about mask, but it doesn’t help.
QuickSave can be managed from within Preferences >> Quick Save. Temporarily increase the time between automatic saves. If you don’t save the UI, the setting will revert to normal when you restart or reinitialize ZBrush.
Thank you for the answer. About the second problem - how can I unmask, or whatever it’s called, vertex when I work on topology with Zsphere? I think this is the problem, but the solution that I found did not work for me. If I use move tool none of my vertices is able to be moved. But if I make another vertex, new vertex, than I can move it.
