[Re: ZBrush 4 running in Windows 7 Pro 64-bit, on Dell XPS 16 (Core i7 820 with 4 GB), ZB compact mem set to 1024.]
I’ve been having problems with ZSketch in ZBrush 4. Sometimes I get a Windows message that ZB has stopped working. No other error message.
Sometimes, I get weird behavior. For example, hitting Shift+A toggles between EditSketch and ShowSketch rather than between the armature and the sketch.
Another example: I created a simple armature from 3 zspheres. I sketched two strips of spheres onto the armature and bound the spheres to the armature. I then saved the tool.
Next, I closed the document without saving changes. The armature disappeared; however the transparent image of the two strips I had sketched onto the armature remained on the screen. Using ^N in Draw mode would not clear the screen. I could still operate the options in the ZSketch palette (EditSketch, ShowSketch, Bind); however, no combination would permit ^N to clear the transparent image from the screen.
I noted that once I moved from Edit/Draw to Draw, before attempting to clear with ^N, I could not move back to Edit. But even if the image was dropped to the canvas, ^N should still clear it.
I tried closing the document a second time. Then I tried loading a new tool, to see if that would clear the old. I’m attaching an image file to show the result. Basically, the new tool in a new screen over-wrote the old screen with the transparency still on it.
Does anyone have any idea what’s happening?
Doc Pit
