Answered: missing surfaces on imported objects
hi there, i’m new to zbrush.
everytime i try to import objects to zbrush
surfaces are missing on the object.
the same occurs with goz.
is someone familiar with this.
thanks for your help!
It looks like you have inverted normals. A quick and easy way to check for this is to turn on Tool>Display Properties>Double. This tells ZBrush to render both sides of each polygon. If the model suddenly looks normal, the polygons are there but turned inside out.
Additionally, you can invert the normals by clicking the ‘Flip’ button in Tool > Display Properties.
great, thanks to you very much.
hi aurick, thank you very much for your rapid help.
best regards from munich and
have a nice day, tommi
