Answered: Lost Lowest Sub-D Level
Hello all.
I`m in a bit of a pickle.
I have been working on a model and have got to the 5th subD level. But i have just noticed my Lowest SubD level is not the original mesh i imported. Its of a higher res!!!
I am assuming i pressed the del lower button in the geometry tab which deleted my original lowest subD.
Does any one know the best way to add a lower sub_d onto the stack? if that is possible.
…or transfer the data over to a new lower res model.
I need the lower sub d for skinning, uving etc…
Many thanks in advance
There are two options:
  1. Use the reconstruct subdiv feature in the Tool>Geometry menu while at the lowest existing level. This will try to create a lower level.
  2. If that doesn’t work you can import the original model again, append it as a SubTool, divide it to have the correct number of polygons, then use Project All to copy the details from the one where you’ve deleted the levels.
Cheers mate.
recontruct subds worked a treat. happy days!!!
Thanks for the help
Purvez
