Hello,
I’m very new to ZBrush and to say that I’m having growing pains with this program is an understatement.
I actually have a VERY important question as I THINK this is the case, and if this issue is the case then I would stop using this program.
Let’s say that you’re creating a tree. You place the piece to extend a trunk from a ZSphere. You place another sphere above the said sphere but the initial trunk piece was either; just wrong, or isn’t working. Could you go back and readjust the first trunk piece?
If the answer is no. Then why in the hell can’t you correct a prior error? Because I know people aren’t perfect, but to find out that you can’t correct a prior error AFTER another piece is laid down seem pretty screwed up to me.
If the answer is yes. Then could someone please explain to me how to do this? This can be pretty infuriating to not be able to readjust a mistake (or choose a different part in the workspace) and would pretty much make this program useless to me (as mistakes can, and do, happen).
Any help would be useful.
Thank you.
