Answered: GoZ and Max 2009 64bit
I have just upgraded to Z4 and installed GoZ for paths to Maya and Max. I’m on XP pro 64bit.
Firstly I can’t find any documentation about this feature - what does it install, where are the directory paths for temp models etc?
Secondly there is no way I can see to determine which app you want to link to. I installed Max first, then clicked GoZ, it launched Max with my startup scene. There are no buttons or categories I can see in Max for GoZ connectivity.
I installed the Maya path and tried again. It worked fine, back and forth no problems.
Now I can see no way to switch Max as the preferred link or any GoZ functions in Max.
Can anyone point me at documentation or offer some guidance please?
-=CC=-
look for the “what’s new in Zbrush” section in your documentation folder.
Look for goZ.
read.
it tells you everything you need to know.
heh, thanks - can you tell I’m a Max user? The only thing they put in the ‘what’s new’ for max is your deflated bank balance.
That’s the biggest ‘what’s new’ I’ve ever seen.
-=magilla=-
ok, now that I’ve actually read the GoZ section I can say that it tells me sweet f.a.
Nothing has been setup in Max - no buttons, no menu items, no categories. There is nothing new in the shared folder (unlike the maya directory which has the shelf)
All GoZ is doing is launching max and a blank startup file. It says “files saved to disk” but I can’t find where they are saved.
I don’t even know what I’m looking for, is it a plugin, is it a macro, is it a script?
In here
C:\Users\Public\Pixologic\GoZApps\Max
there is a bunch of crap
This is supposed to go here
C:\Program Files\Autodesk\3ds Max 2009\Scripts\Startup\Macro_GoZ.ms
C:\Program Files\Autodesk\3ds Max 2009\SendEventToMax64.dll
This installs a GoZ menu in Max
There… now how hard would that have been to include in some freakin documentation!!!
idiots.:mad:
Hello,
In order to set/change the currently linked app, you can click on the ‘R’ button on the right hand side of the GoZ buttons line.
thanks Max33 - repeated installs did nothing. As stated in the previous post all of those elements needed to be manually placed in the correct folders.
Im on win 7 64 bit. Running max 2011 64 bit. All I had to do was install goz into the ZB exe that lives in the program files folder on drive C.
