Thanks thats great. Both ways work. Couple of questions though,
aurick: With the curve suggestion its very tricky trying to get the distance correct between bolts. Im keeping the curve step low at 1 so the bolts just touch, if i wanted to increase the space i assume a curve step higher would work but it doesnt and then just explodes the curve. Trying different brush sizes and smoothing seems to help but it all seems a bit random. Im adjusting the curve step, then smooth, select curve, curve step, smooth, select curve.
And when happy, how do you finalize the curve and objects?
zber2: that is an easier method, Is there a way of randomising the rotation of a multimesh object ie bolts so theyre not
all aligned the same way. Been through all the brush modifiers but cant seem to make it random.
thanks again
Paul
