Ello,
I have been trawling through a lot of the memory error threads, 3gb switch, and multi threading threads and as far as I can tell i will need to ask this question for myslef cos the answers are very much tailored to the individual.
the problem is that I get a memory error message with zbrush 3.1 whem I subdivide a piece that I am working on up to 8 million poly’s. It tells me that I have insufficent ram and that it is unable to process the task, but upon clicking o.k. it still shows the model at 8 mill polys and i can rotate around the piece with no lag at all. If I try to put a brush stroke on the piece though the same error message comes up.
This is a new computer set-up for me with the following specs:
intel core 2 quad cpu @2.83GHz
4gb ram
280 gb available on the drive that zbrush is installed
nvidia inno 3d gts 250 1gb graphics card
i’m running windows xp professional sp3
my memory preferences are as follows:
compact memory is set at 2000
maxpolypermesh 9,75 ( this is the amount that the system chose which adds to the 8mill memory error confusion )
doc undo 2
tool undo 1
should I get the computer back into the shop and change the OS to vista so that it will allocate more than 2gb ram to a program, or has this issue been sorted with sp3?
I do appologise for asking this old chestnut again but I really am at a loss with what to do.
thanks tons in advance
