An easy way of polygrouping overlapped geo?
I’ve run into this problem a lot while sculpting clothing especially where it folds on top of itself as is the case with things like shirt or jacket collars and such. Is there an easy way to move this stuff without inadvertantly pulling stuff behind it? It is literally impossible to mask it out because there is no way to mask the backside of the folded geo without selecting other portions of the object. I know you can mask by uv’s but I uv’d the object in max already as one contiguous shell and I couldn’t paint seam protection and use uv master either since there is no way to get at the inside of the fold within zbrush. There’s probably a way around this that I’m not thinking of but just in case I figured I’d ask here. Thanks.
Some info here, may be helpful.
http://www.pixologic.com/docs/index.php/New_Brushes%2C_Settings_and_Behaviors#Move_Parts
