I’m trying to get to grips with the selection tools to create polygroups.
When using the masking tools (ctrl), specifically the curve tool, I can click the alt key multiple times to create a curve and double click to create a sharp corner as expected.
When i’m trying to select (shift+ctrl) I click alt and a curve starts but clicking again doesn’t continue the curve, it turns the selection from green to red (inverting).
Am I missing something or is this normal behaviour? The book i’m currently learning from suggests that you should be able to create selection curves in exactly the same way as masking, except I can’t!
I’m using a mac laptop if that helps (i know sometimes the reduced keyboard can throw up odd behaviour)
Thanks in advance!
