Alphas question? Very annoyed
So I am following all of the tutorials in the Zclassroom currently.
I am trying to load an alpha from lightbox, but when I double click it it just loads up a flat image of the alpha with some type of editing tool. Not only does it not just select the alpha that I double click, there is no way to just close the box thing it loads up, unless I click delete.
What version of ZBrush are you using? You might like to following the policy described here so we can help you more easily.
you’re putting files directly to spotlight.
shift+z will pull you back out of it…or maybe z…don’t remember off hand.
