Alpha sculpt projects through mesh
Is there a reason why when using a Drag Rectangle brush (or other brushes for that matter) and an alpha the alpha image sometimes “projects through” the model and shows up on the opposite side as a negative version of itself (see attached .jpeg)?
At first I thought it was my UV so I tried it on a stock Zbrush shape and got the same effect.
It looks like as the shape gets bigger this effect happens more often and of course any alpha that is scaled so it bleeds off the edge of the model always shows this effect. But I can get this effect even when the alpha is no where near an edge.
Is it only happening on relatively thin tools like that star? Try hiding the back faces when you’re doing the drag rectangle operation.
db
