lately in zbrush and am creating more and more alphas but now startup alphas are starting to slip off the space that zbrush give me. is there a way to increase this space or to delete the alphas?
thanks
thanks
The startup folders are meant to hold items that you use constantly. They’re not for every little thing you think you might like to use at some point. For one thing, every item you put in those folders takes up system resources from the moment ZBrush launches. So you do want limits! Don’t put more than 20 or 25 of any given item in the startup folders.
For your other alphas, check out the Alpha and Texture Loader plugin. It’s found here: http://www.pixologic.com/zbrush/downloadcenter/zplugins/ (And if you haven’t been there before, be sure to also check out the Alpha, Texture and MatCap libraries. They’re all free.)
