Alpha on Lightbox
I don’t understand how this works, when I Shift + Double Click any Alpha in LightBox, it doesn’t go to Alpha box on left side, it’s putting on texture box. I don’t want it on texture. how i can fix this?
sorry my english is not good, still learning
NinjaMax
bump
This doesn’t happen for me. The alphas go to the Alpha box on the left panel. Are you certain you’re clicking on alphas in the Alpha folder in Lightbox?
Are these alphas you created yourself or ones you downloaded from somewhere? Or are they the default alphas that come with ZB?
If they are not the default ones they may not be true greyscale image and for that reason may be treated as textures rather then alphas by zbrush. Try this: When the alpha appears in the texture window, click “make alpha” then export that image into your lightbox folder and try shift-dble clicking on the new version.
thank you so much!!
