alpha masks and topology issue
hey all!
i have a issue concerning alpha-masks. i have made a picture to help show the problem.. say i have a model with topology like in no.1 and 2... but would very much like a masking result like in no. 3 -with clean lines. is there any way that can be archieved? i need the fine clean masking lines because i already have the desired alpha and have to edit the mesh according to the alpha later on. -and end up with a decimated mesh. [maskingIssue.jpg[/ATT]%3Cbr%20/%3E%0A%3Cbr%20/%3E%0A%3C/font%3E"]![maskingIssue.jpg|1200x960](upload://p1YSHa59qJWRWiCUKYsxOr86BGT.jpeg) ](http://%3Cfont%20color=%22#9A9A9A%22%3E[ATT=239677)please write back if anything (or all) was unclear.. -r
Is this mesh unwrapped, and you apply texture from which you make masking ?
If so, maybe try extracting mask on higher sub-d level.
But i think you neeed to work on the topology ?! Add some more detail to the base mesh before importing to ZB.
Actually i never had such a problem with extracting masking from texture - if your model is uwrapped correctly.
