alpha keep coming
There is an alpha problem keep coming. When I have selected a different alpha image and the alpha image on the brush does not changed. What can i do to restore them to be like a spot light?
I have even restart the whole app and the problem is keep bugging me.
please help me.
the image is here:
http://www.box.net/shared/lcf47lays0
as you can see. my cursor is on a different pattern which does not match from the alpha pallet. This problem now happens to me constantly. I just need to get this done.
thank you.
Looks like you’ve got Spotlight on. Press Shift+Z to turn it off.
exactly, I have my spotlight on but it does not help when i turn off the spotlight.
my alpha still remain the same as the wrong one. I have no way to change it back.
To change an alpha on a brush, click on the large alpha thumbnail on the left of the interface and select the alpha from the pop-up.
To load an alpha from Lightbox into the Alpha palette, hold Shift and double-click on the alpha thumbnail in Lightbox. It’s a good idea to turn off Edit before holding Shift, otherwise the alpha will be applied to the Smooth brush. Simply turn on Edit again before continuing sculpting.
wow. I did not know that. Let me try it and I will come back again.
after I have tried your method. I have found out if that will work when spotlight is turned on.
I “hold Shift and double-click on the alpha thumbnail in Lightbox”. My alpha on my cursor does not change still with my spotlight turned on or turned off. I have turn off or on the EDIT to change the alpha. But it is not working. I have also tried to load new alpha from the Lightbox and i got the same result.
As you can see this… I wonder if that is the active bug or something i have not done correctly. http://www.box.net/shared/rd6hp8mj4z :cry: :cry: :cry:
