After appending, how do you scale?
I create a pair of boots for my model. I load the model, then load the boots. I hit Append but then it merges the two together and I cannot scale them separately. When I go to scale it scales them both at the same time. Newbie needs help! Thanks
In subtools select the boot. In the deformation panel is a scale function slider with the 3 axis. There is also a set of sliders at the bottom of the geometry pallette. Hope that helps. The scale you’re probably using is all subtools relative to the canvas.
