aurick
Before you divide the model (or a subtool), press Tool>Morph Target>Store MT. This is because multi-res subdivision editing means that any changes made to one level are translated to all other levels. Well, when you divide a model, the smoothing process causes it to contract. This then results in shrinkage when you return to level 1.
After returning to level 1, press Tool>Morph Target>Switch to get your original base back. Be sure to switch again before returning to the higher levels, or the base mesh restoration will translate back up the line!
Another thing you can do is to press Tool>Geometry>Crease before dividing. This will prevent the edges from contracting, although the rest of the mesh will still do so.
TimLIVID
Hey Aurick
Thanks for your response. I think that has solved one of my problems. My main aim is to make a normal map to take into Maya and render from there so I trust that either of the two methods you outlined would get me to this goal.
Goast666 is helping me with the other problem (in between Fable II) so together we should get this model finished.
excited clapping
Cheers again.
So I was thinking of conducting a test.
I went to the digital tutors site and had a sample look at some of their tutorials
http://www.digitaltutors.com/store/…?productid=3385
I had a look at lesson 13 and followed along as the Rhino is a demo model that you get with the program. I chose the same brush and intensity and divided the model to the max and low and behold I wasn’t getting the same detail level as the guy in the tutorial.
I don’t want people to think that I am needlessly bumping this thread up for the sake of it but I just feel that the titile I orignally gave it doesn’t fully convey the type of problem that I am having.
It would be usefull if I could change it or start a new thread with a better titile and just repeat the posts that have been posted here.
I just feel that poeple out there must know the solution but are probably not looking at this thread beacuse of the shoddy title I have given it.
Just my thoughts anyway. I will give a day or two and see what I shall do.
Cheers.
