Hello!
I hided polygons and want to add edge loop to vioble polygons. My problem is that new loops are near border of visiblepolygons. And wire is not uniform. Can i shift inside new loops more from border?
I think the only solution is to use move brush.
Thanks
I have levels in model, so if i will use move i suppose at higher subdivs my model will have changes.
I would like to see standard edge loop, if you ask me :))
to get the edge loop where you want it, you have to use masking and transpose, what you do is move the edges of the visible piece to where you want your edge loop, then hit the edge loop button.
spaceboy412, if you say it, I belive it’s great!
Can you describe it more, i can’t actually undestand, should i move visible edges?
