Adaptativ Skin poseable questions.
Hi :wink:
I try to correctly understand the operation of “ZifA” with the use of a character whom I try to articulate as in poser for example.
I know that much works on this handling which remains very mysterious, and oddly no explanations on this subject which however seems one of the most advanced tools of Zbrush.
I find npt reponses in the posts precedents and god alone knows that I visited some.
here, one above good once for all can to be clear it?
exist there fixed rules allowing to avoid the errors which you see on the following images.
[img]http://www2.zbrushcentral.com/uploaded_from_zbc/200312/user_image-1071820044cnq.jpg[/img] [img]http://www2.zbrushcentral.com/uploaded_from_zbc/200312/user_image-1071820086cxf.jpg[/img] [img]http://www2.zbrushcentral.com/uploaded_from_zbc/200312/user_image-1071820127uao.jpg[/img]
as you can note it here is the type of error which I meet.
and that without reelle logic, few times for an identical rotation of a member, the result will be different.
And that does not arrive systematically, some times I can practically move my character without many problems,
other times it be enough to a degree to rotation and poufff!! alls meshes crashed or it reset modeling.
all that appears quite hazardeux to me, I suppose of course that there is a logical explanation to all that
thank you :slight_smile:
Could you post your Ztool and it’s texture, plus settings, so we can have a common point of referance to try and figure out what is going wrong? I know the difficulties that Zspheres have given me! Maybe, if we all work from the same model, we can find some answers to some of your problems, and lock down proplem areas that we could bring to the attention of Pixologic.
yes frouad b i have the same while posing
zifs in preveiw mode but i believe the next version will be different that is why i try not to spend to much time on this subject.
something to do with the pose being kind of out of range for the mesh to handle.that is why i pose as much as preveiw mode will allow then make adaptive skin and finish posing as shown in my adaptive pose post.take care happy holidays to you. :+1:
p.s.to sirquadalot good idea if your interested in working together so will i see my recent post,let me know .i think
all members can get together and make
a sort of defaualt poseable male and female
like mayas meg and posers posette for example.
