Activation issue...
This is strange. Last night I was bored inside my Ubuntu partition and for S&G’s i tried to load zbrush from my windows directory via WINE. It opened up the program and was asking to activate and not wanting to really mess with it further I just exited the application without messing with the activation. Now, in Windows I loaded it up and first it asked me activate and I entered my code and it took it and I was able to work like normal. Now that I’ve closed zbrush and tried to open it again it is asking to activate and after putting my code in it keeps saying that it has failed and to activate via web, email, or phone. I am running Windows7 and I did run Zbrush as administrator. Any idea what I can do?
Okay, this is resolved. I had to go through the motions of the web activation even though it just gave me the same code but now it is working. That’ll teach me to play with Linux…
Hey man ,
Can you tell me how you did that ? I means to say how you resolved it because I think that I’m facing the same problem with my PC …
Wow this is very upsetting I installed zbrush ran it as admin. Entered the activation code that was sent to me and I got a activation error? Does somene have a answer? I have contacted Zbrush but sofar no help from tech support, Must be short handed. Does someone have a answer?:mad:
Did you try to enter your serial number as an activation code? If so, what you need to do is choose Web Activation. Fill in the form – which will request your serial number, and will then give you an activation code. Copy the code that the web page gives you, then switch back to ZBrush so you can paste it in and complete your activation.
Hello,
This is done with me .I also got the activation mail to late.But at last i got it.No worry about that.
