action Line disappeared?
How do I get my action line back?
You haven’t given enough information to try and help. We have no clue what the steps were that you were following or what buttons/shortcuts you used.
sorry aurick, I hate to say this but I have no idea what I was doing. It could have happened at any time during the process since I had used transpose maybe hours before I noticed it being gone. I often times use shortcuts and accidentally push the wrong ones but usually just tap it twice if I notice i’ve done something wrong. The other issue is… I am still such a newbie It’s hard for me to pinpoint it. I will try to think. In the meantime I’ve turn zbrush on and off several times to no avail. Could it be a settings in the startup config. I usually hit save start up config instead of inverse but usually don’t bother resetting it since the config issually fine.
what is the action line?
that’s a action line
um transpose line just comes up when you leave Draw mode and enter Move,Scale, Rotate on polymeshs, not on primitives.
exactly, but mine is not
