Accurate stitching along an edge
Hi guys,
Im currently working on a car interior and now completely stumped as to how to achieve realistic looking leather stitching.
Is it possible within zbrush to select an edge and run an alpha around it a changeable amount to create holes or stiches on an object ?
The object is a headrest and so fairly orgranic in its shape. I have good edge loops.
Any help is really appreciated,
Cheers
Steve
I think the stich-brush is ideal in this case. The alpha which comes with this brush is great and because of the lazy-mouse is on, you have very precise control over your stroke. It will follow the model`s contours easily.
you could also create a stitch pattern in 3D and create a zsphere chain that follows your mesh geometry, insert that mesh into the zphere chain and away you go.
though the stitch brush will probably work faster.
Hey goast666, I was wondering if you could explain the zsphere chain a bit more. This technique sounds quit interesting.
Thanks
JM
http://www.pixologic.com/docs/index.php/Joseph_Drust#Using_Appended_ZSpheres_to_Retopologize
