Accidently assigned something to C shortcut - how to re-assign?
As I was just about to start coloring my 3Dmodel, I realized that I had assigned another hotkey to the C shortcut for picking colors.
I wanted to reset the hotkeys, but the “restore” button is grayed out in the settings. Nor can I find any color picker button within all the menus. – Is the button for the color picker hidden somewhere so I can reassigned it to C or do I have to do it another way?
Is there somewhere I can download the default StartupHotkeys.txt, because when I look inside them, both say [BRUSH:MOVE,99] // C , which I don’t want.
Re-installation seems a bit drastic.
Thank you
Click on the color selection icon and, while holding down LMB, drag to where you want to sample the color.
That works a little I guess, but its no where as efficient as the C-shortcut. I just want the shortcut C to work again, so I can pick colors from wherever I want without having to go back and forth.
I never reassigned any keys, so you can try my StartupHotkey.TXT file if you want.
That worked! Wonderful! Thank you so much. :smiley:
Your welcome! Glad it worked. :slight_smile:
